Shows the L3 VNI entries from the EVPN MAC/IP table.
| bgp | Specifies showing the BGP configuration. |
| evpn | Specifies showing the EVPN configuration. |
| l3vni | Specifies showing the integrated routing and bridging IP VRF VNI configuration. |
| vr | Specifies showing the VRF. |
| vr_name | Provides the VRF name. |
N/A.
If you do not specify a VR, all VRs appear.
The following example shows all L3 VNI entries:
1 # show bgp evpn l3vni VRF Name Layer 3 VNI RD -------------------------------- ----------- ------------ vr-a 10300 2.2.2.2:10300 vr-b 10100 2.2.2.2:10100 vr-c 10200 2.2.2.2:10200
# show bgp evpn l3vni vr vr-b VRF Name Layer 3 VNI RD -------------------------------- ----------- ------------ vr-b 10100 2.2.2.2:10100
This command was first available in ExtremeXOS 30.6.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
